- Joined
- 20 Oct 2015
- Messages
- 9
- Reaction score
- 0
- Country
Hi.
This is my first post so forgive my novice status. I've had a look around a few forums but couldn't find info so thought I'd take the plunge and post.
I'd like to fit sone additional sockets to a dinning room. I had an electrician do the living room but it created such a mess drilling into wall that I thought I'd chase the sockets myself. I figure if I take my time I'm likely to be more careful and less messy.
What I'm not sure about is the depth of patress to use. I bought a 25mm drew around it again wall and started chiselling away. It's a 1890 built home. Managed to chip away enough plaster that the patress fir flush without having to drill into brick. Having read a forums I expected the job would be a lot more difficult then that. So its making me think I'm using the wrong depth of patress. Should I use 35mm? If so, why? ( so I can understand better what I'm doing).
* just to say I'm installing sockets into wall that divides living room and dinning room. After chipping away at about 25mm of plaster there is a single thickness brickwall. Also I plan to do a skim plaster after fitting electrics so that is likely to add an extra 3-5mm.
Any advice would be great. Happy to provide more info if needed.
