Advice I compound Mitre Saw
11 Oct 2003
Glamorgan
I'm looking to buy a mitre saw, but I'm torn between two
The first is a non sliding bed with a blade of 255mm
and the second is a sliding bed with a blade size of 210mm. Which should I go for?
a sliding mitre should give you more flexibility as it will cut wider boards, check the specifications for cut sizes before making a decision
These are the specs on
Straight cut 67mm X 140mm
Beval cut at 45 38mm X 140mm
Straight cut 60mm X 200mm
Beval cut at 45 42mm X 200mm
The sliding bed is made my pro, and the non sliding bed is by Rexon
B&Q do one made by PRO think its £150ish it also has a laser line guide which is usefull altho it does get dirty every other cut :lol:
heres a pic
features
Powerful 2000 Watt motor with the power to handle tough timbers & severe cutting tasks
No load speed 4200rpm
Blade diameter 250mm, blade arbour 30mm, blade teeth 24 TCT
Laser line generator for improved cutting vision, faster set up, accuracy of cut & increased safety
Dual ball race rail sliding system for an accurate & smooth sliding action
Precision bevel cutting up to 45 degrees
Mitre cuts 0 - 45 degrees left & right increased versatility
Positive stops on the table allows fast & convenient setting
Polished aluminium mitre table high strength to weight ratio
Spindle lock button allows single spanner blades changes
a compound miter saw that slides is more usefull and does more jobs
That B&Q sliding mitre saw with 210mm blade has a depth stop which allows you to cut housings although the blade doesn't reach full depth at the back of the slide unless the stop isnt used.
A bit of 2" (50mm) wood against the fence should allow a full depth housing over 6".
I found mine usefull for cutting tenons once I realised its limitations.
