I've got a Cambridge Audio A5 Amplifier which has suddenly decided to stop working. When the power is turned on nothing happens except from a quiet buzzing from inside the unit. I looked inside to find two fuses have blown. They are 20mm x 5mm glass fuses and have T4AL 250V stamped onto them. The other end of the fuse has all sorts of marks (British Standard marks etc.) and 50T stamped onto it.
I can't seem to find anyone in the UK who sells these fuses though? I'm starting to think that the same fuse sold in the UK is called a different name or marked up differently, but I haven't much of a clue about electrics, so even if I'm right I couldn't figure out which fuse was the right one.
Does anyone know where I can get a replacement fuse from or if there is a compatible fuse I should be looking for?
Thanks.
Thanks.
