Bathroom project - attaching tile backer boards to solid brick. Primer ?
31 Mar 2015
Yorkshire
Hi everyone,
I am currently doing a wet room project. I have purcashed foam core backer boards, 10mm for walls and 6mm for floor for The Wetroom Store. In the instructions one method of fixing the boards to solid walls is tile adhesive, and attach in a brickwork pattern. I have Mapei Keraquick rapid set S1 flexible adhesive, the company said it's fine to attach the boards directly to brick, but will likely need a SBR based primer, and be clean/free of dust, and to refer to the adhesive manufacturers instructions. There isn't much info regarding using the adhesive on brick so that's why I'm here. Just wondering if I'm ok doing this ??
Any help much appreciated
Andy
I'm no pro, but I painted the bare brick with watered down sbr, then dot and dabbed the boards, with 6 mechanical fixings per board, with washers.
Don't be stingy with the dots, you don't want the boards flexing if tiles are going on them.
If you've hacked plaster off back to brick, think about insulating the outside walls (especially if it's an older house with solid walls)
I used 40mm marmox boards to get at least some insulation, whilst still being able to fit the bath in
Edit- I also ran a bead of ct1 along each edge of the board (think like mortarting bricks together) to make sure the joints are waterproof
