Beko DIN15x20 Integrated dishwasher
25 Jun 2021
Hi all,
Thanks for taking the time to view this.
I have the above dishwasher and it is having issues.
When selecting a programme, it defaults itself to P1. However, it doesn't wash. Makes all the noises and just beeps.
I tried multiple tests and in the end ordered a new PCB and installed it.
Guess what, still doing the same thing. Changing programmes more times than Katie Price changes husbands.
So I decided to take it all apart and clean all the tubes, check the pump impeller and even attach a hose to run the water back through the salt reservoir.
It is still doing it.
Any ideas?
I also noticed that water just constantly runs in from the top funnel, but it does drain and empty.
Pics/videos attached.
Well, I took a chance and replaced the water flow sensor...
Seemed to fill and do what it was supposed to. Then..... it now constantly drains again.
I give up, you win dishwasher!
Randomly started working!!!
Did 3 cycles, now it just wants to drain 24/7....
Is it the Drain pump?? Despite it actually pumping water out is it confused and only draining and not cycling the water around?
Changed the Drain Pump and worked for 3 cycles.
No back to wanting to drain all the time.
Not pumping in water.
Any ideas from anyone please??
How have you got on ? Mine was working fine and then I wanted to cancel a program, and followed the instructions. Subsequently I get either a p1 error or a p2 ( no water /too much water -how can both be true) plus it won’t switch off unless I power it down at the wall. Beko have quoted minimum £125 to repair, 55% of the purchase price at least. Like yours , it just hums until it beeps with the error message. Did you manage to fix yours?
