Bell tamper and battery low
19 Jun 2019
Whilst away I received a notification from my alarm of a bell tamper and immediately after a bell battery low warning. It’s a Texecom Premier Elite 64
Neighbours were there and there was no tamper.
Unarmed and rearmed.
Ok for 6 days then exactly the same again.
On returning home there are no errors on the keypad, guess the tamper was reset when using the app. The log shows the tamper, nothing about the low battery.
Any ideas what this could be or what needs to be done.
Dave
I would go with the bell tamper message, the battery does not last for ever, so ladders and notebook out, get the battery details and replace soonest or you will have a problem at the most inconvenient time .
Don't do this at your own peril. NOISE.
It’s wireless and installed Feb this year.
Other than installation test the sounder has not gone off except for these occasions.
Battery low and tamper is in the logs, but nothing on wireless keypad when arming.
Dave
Are the comfort LED'S turn on the bell box ?
If yes this could have drained the battery life !
I understand that one or more of the batteries could be duff, even though they really shouldn't be after such a short time after installation.
The low battery warning came up after the alarm went off straight the bell tamper, which i tend to get as the current drain due to the alarm would lower the voltage and could lead to the battery warning.
I can change the batteries easily.
But I still do not get get what caused the random 2 tamper alarms a week apart.
Dave
nothing is truly random.
bell tampers not properly secured, bell box not properly fitted to the wall, seen some wireless devices show tamper if they get hot.
Replace all batteries, while up ladder adjust microswitch on bell box.
Make a note when you changed batteries and see if same occurs a few months down the line.
If you have a multimeter ....out of interest see what each of the batteries have left in them ....
