Hi All,
I am performing a self build and have got a plan for opening the corner of the extension with 2 seperate bifold setups around the corner. In the middle holding up the corner there will be a 150mm vertical steel beam with steelwork then running off the top horizontally to each wall at the other end to form a lintel to hold 3 brick courses above the bifolds. The SE prefers to have the steel upright in the corner in the internal face of the brickwork.
My question is surely this internal steel would not work as the bifolds will be sat on the external face and how would the bifolds support themselves at the far end in front of the beam and also how would we hide the beam?
If I put the vertical beam on the external face instead how do you then prevent cold bridging as it would add a lot to its thickness adding insulation and a metal covering?
I have tried to find pictures or a detail of an installation like this and not getting anywhere!
Many thanks in advance
