Tumble dryer is around 4 years old and a year ago noticed that it is cutting out at random points during the drying cycle. The reason for cut out on the display is a fluff filter or heat exchanger issue.
This model (after reading reviews) is notorious for this problem and did a little bit of digging online. Suggestions were to clean out the sump at bottom of machine so it’s free of debris and give the pump a good clean. Took the whole pump unit out and inlet and exit points were not clogged at all. I was hoping it was this but while the machine was in bits I cleaned every other part of the machine including the fluff sensor and the sensor inside the drum.
I have put this back together and it’s still cutting out. I’m trying to work out which sensor it could be before buying one and hoping it works! Is there any suggestions what it could be or what to check for?
I also manually checked pump operation by filling the sump with water and seeing if it emptied out the pipe when switching on and all seemed normal.
The model is Bosch WTB84200GB
