- Joined
- 29 Sep 2018
- Messages
- 7
- Reaction score
- 0
- Country
Hi. I'd be grateful for some help please.
I need to turn off the power to my Texecom Premier 24 (V8.00) to do some upgrades, but I can't get the bell into hold-off mode so it goes off when I remove the power to the main panel.
I think (but am not sure) that the bell is a Texecom Odyssey (though suspect it's quite old). It's hexagonal, with blue plastic at the bottom with a white strobe and two red leds on the left and right and side of the blue bit. The proportions look a bit different to the current model though - the shoulders are smaller. It's branded Town & Country.
I've tried pulsing the strobe three times within 30 seconds using the panel. Engineer Utils > Bell Test > Test stobe, then pressing yes several times quickly to turn the strobe on and off. That's supposed to put the bell into hold off mode, but doesn't appear to do anything (the two red comfort leds still flash intermittently). it still sounds when I pull the power. The strobe light does flash when the strobe is turned on, so clearly the wire is connected/functioning.
Did the older Odyssey bells not have hold off mode? Is there any other way easily to hold the bell off? Can I connect the 12V bell supply and Bell- wires (from the bell) directly to the 12V battery, and then disconnect the power from the panel please?
Andrew
Andrew
