My kitchen floor had been tiled with porcelain tiles (33x33 size). Part of the floor was done using Kerakoll H40 supplied by the tile shop. Unbeknown to me the tiler ran out of this, and instead of buying more has used Mapei fast set instead. The info specifically says this mapei is for ceramic, and not to use for porcelain. Is this a problem? What issues could it cause?
To add- my floor is 9.26 sq m. 40kg of the Kerakoll were used which the tile shop said would be sufficient. The tiler has used an additional 120kg of the mapei. He said to help level out the floor where he removed the old tiles. This seems a significantly large extra amount.
thanks.
thanks.
