Connecting Texacom Alarm Box
18 Sep 2012
Yorkshire
Hi, I'm new and have a query about replacing my old alarm box with a Texacom Odyssey. My old box does not have a brand name.
The old box has 4 wires connected, 12v - 0v - R - S The Texacom needs 5 connections 12v - 0v - Bell - Tamper - Strobe
If I am correct in assuming that S is Bell Strobe and R is tamper. Would I be ok to link Bell and Strobe on the Texacom to achieve the required connections ?
it could also be -s for siren!
or -r for ring
check the outputs from your panel
also, what panel is this oddy siren going onto?
Oasis
Thanks for response. The key panel is a Scantronic 9200 but there is no brand name on the control panel (just a plain metal box with circuit boards inside).
The cables in the control panel are:-
Black - Neg - 0v
Red - Pos - 13.8v
Blue - TR - 0v
Yellow - TRIG - 12.8v
Hope this makes sense.
9200
well you should have either a relay for the strobe or an output for it you (if there is a relay) you will have to take a negative to the common or `c` side of the relay and connect the strob e neg 0v to the NO normally open connection.
but as i have not done any scanny work for donkeys years cannot remember!
trig is for your siren
0v is the neg to your neg hold off
pos 12v is for your + hold off
TR is your tamper return
hope this helps
if it has not got a strobe output put it into sirten output of your bell box
hi team am a new technician, can anyone assist me how setting a time in Texacom Pannel
(Tanzania)
