Correct tool for a rebate joint
31 Jan 2014
West Midlands
I'm building a garden pergola. The posts are 100x100mm green oak. And I need to cut a rebate in the top of the posts to fit the 88x32mm cross beams.
What would be the correct power tool for this ?
A rebate?
Do you mean a lap joint or a bridle joint? Either way, a power tool wont be the correct tool. Hand saw, hammer and chisel.
Yes a lap joint looks similar, or half a lap joint anyway. Like this kind of cut https://i.ytimg.com/vi/joFoPcBhf4Y/maxresdefault.jpg
The guy in this video shows the same kind of cut I need.
Since my posts are 100mm square I was hoping a circular saw with 62mm cut depth might do it in 3 cuts (1 horizontal and two vertical), save me some hard work sawing oak by hand. I am only a rank amateur though so if you think hand saw is the correct way to do it then that's what I'll do. ANy recommendations for a good hand saw ?
Also, I'm not especially good at getting a good clean straight cut with a hand saw.
Sliding mitre saw with a depth cut set. Make several passes a few mm apart and knock out the rest with a chisel.
Now we know that you have a circular saw then yes, that would be a better way to proceed, but because you cannot cut it out completely with a circular saw you'll still need a hand saw to finish the cuts
If you have a speed square you can use this to guide the saw making a series of parallel cuts starting at the outer end and working inwards to replicate the curts Mr Rusty has suggested doing on an SCMS (but at a fraction of the outlay). I must say I find this a tad tedious to do, but it's another approach
