- Joined
- 22 Feb 2016
- Messages
- 31
- Reaction score
- 1
- Country
Hi. I bought my Victorian end-of-terrace house 2 years ago and am still trying to solve a problem with dampness in the subfloor void. As you'd expect, this has caused a lot of damage to the timbers, mainly wet rot and wood beetle damage.
Photos are here: https://www.dropbox.com/sh/q38spc43qjdn8ht/AADmcEs7GLdQ9bTLiAPx6Gj4a?dl=0
The air bricks are clear (2 front and 2 rear), and there are several large holes in the two sleeper walls which flank the staircase, so I think ventilation is adequate.
The sleeper walls are damp and salty, and have partially rotted the timber wall plates.
The brick piers are also damp and salty.
The wall plates that were sitting on the constructional hearth have all rotted badly.
I had the chimneys and parapet walls flashed when I moved in (previously cement filets), and am about to have the cracked flaunching replaced, which the first roofers had stupidly not told me about. I've also just had cowls fitted to the 3 pots that were left open.
Due to the speed at which the timbers are rotting, I don't see how this level of moisture could be normal, and it's only along the side with the chimney stacks on (external end of terrace wall).
There was a house previously attached on that side, which was destroyed by a WW2 bomb, and the chimney breasts that belonged to that house are still there. The upper flues are ventilated, but the lower ones aren't, so I'm going to address that. I'm also planning to Stormdry the ledges where rain has been soaking through the cement render.
Do you think it's possible that this problem has been caused by water coming down the chimney, or is that unlikely given how damp everything is? I've had drains and water supplies checked to no avail. I'm also waiting for the council to come and clear the roadside gully which is completely blocked.
I've done my research on what needs to be done to replace the timbers etc, but I still don't know how to address the root cause of the moisture ingress.
Any advice would be hugely appreciated. This house is driving me mad!
Thanks,
Joe
Thanks,
Joe
