I have just installed low voltage lighting throughout my house which use electronic transformers. Although it states I can use either leading or trailing edge dimmers I have purches trailing edge ones.
The wiring diagram they come with is as clear as mud and it is impossible to get any info as here you have to be a tradesman to so much as flush the toilet.
The everyday switches here are all two way with loop, common, 1 and 2 all on the back of the switch.
Now do I merely insert the dimmer inline by taking the switched live from terminal 1 and wiring one leg of the dimmer into the switch (1) and the other on to the cable i've just removed ?
Can anyone explain the differences between traling and leading edge ?
