Double storey side extension - next to council allotment
31 Mar 2011
London
Q: Can I build a double storey side extension, all the way up to the side boundary, where on the other side is an council-owned allotment?
Context: House is semi detached. On the right is the attached neighbouring house. On the left is a 4m gap to the boundary. On the other side of the boundary are no buildings for half a mile, just allotments.
I'm thinking of purchasing this property. I know that if the left boundary was typical (e.g. facing another semi-detached house or a highway) that there are strict restrictions on a double-storey extension and also on how close to the boundary you could build. But in this situation, where the boundary is to an allotment, does this change anything?
I know that this wouldn't fall under PD and I would still have to get full Planning Permission, but should I even have hopes this could be granted?
You would need to look up your council's policy guidelines for side extensions.
Some councils insist on setting the front of the extension back a little from the front of the house, to avoid a terracing effect if all houses on the road extended to the front - though that would not apply here.
Similarly, some insist on a minimum distance to the side boundary.
You would almost certainly get a decent side extension approved, but how big.....?
Remember, you don't have to own a site in order to make an application on it - although a successful application may force the purchasing price upwards!
