Hi, I Last year. I installed a dusk till dawn switch, with a built in timer, to control all of my outside lights and pond lights. This works as it should they come on if it's still dark at 7am and they come on in the evening as soon as it's dark and go off around 11pm Great!
However there has been a few occasions (Noises outside, or if i've forgot to put the bins out in time) were I'd like to be able to activate them manually after the 11pm curfew.
Now I was thinking of just providing a link via a switch to bypass the optic sensor, but I'm not sure if doing this may damage the photocell? Would it work or be better to use a relay were the N/C contacts are wired as they should be and the N/O contacts be the new + feed via a switch that would activate the relay? Or is there a better method.
Brian
Brian
