Hi, I'm looking at window sills for a self build with a cavity wall and want to know how entrance door and sliding patio door sills are secured to the brickwork.
I will have 1 x patio door 1800mm wide with short sill, a 1000mm wide side door short sill, and a 1000mm wide front door with low level threshold.
I know that window and door frames are fixed through the sides into the brickwork or via window straps to the inner cavity wall, but are the plastic sills mechanically fixed down into the brick work penetrating through the DPC, or are the sills only screwed into the door frame and then the only fixings are then through the frame sides or via the straps?
