I'm planning to mount a TV on a chimney breast and am trying to work out the best way to hide the cables (a power cable, HDMI, and possible an Ethernet cable.) What I picture in my mind is putting two holes in the chimney, one behind the TV and one at the side and connecting the two with some kind of flexible conduit, perhaps 40mm or 50mm in diameter. The ends of the conduit would then connect to brush plates or similar, in much the same manner that you might connect a tumble dryer vent to a vent wall plate. The idea is that I am future-proofing the installation to a certain extent so that I could remove or install different cables sometime in the future without having the knock the chimney breast around.
Trouble is, after literally minutes of googling, I can't actually find such a thing. I can find the brush plates and the conduit no problem but nothing apparently that ties the two together. Is there such a thing?
