Hi guys.
I’m doing a garage conversion in my house and on my plans it says to use 150mm timbers for the floor joists. The problem is with 150mm the joists will sit directly on to the current concrete garage floor. I’ve read some where there should be a space of 150mm below the joists for damp raising. Can I use a vapour barrier between the concrete and bottom of joist or will that cause other issues.
