I've hit a problem trying to format a HDD and I hope someone can help me to overcome it.
The PC is very old (so is its owner), It had a 1GB HDD, the OS was Windows 98. As expected the hard drive was full to the extent that an additional 3 lines of text would crash the system.
I bought a 8.4 Gb HDD from a car-boot and tried to install and format.
Halfway through fdisk it showed that it was NTFS (1st problem) so I had to go to Seagate and d'load a 'Disk Wizard' application. That worked fine, it changed NTFS back to FAT 32. Win9* & NTFS are incompatible.
Once I had changed the filing system I thought everything would fall into place and loading the OS would be a breeze. Well I was wrong (2nd Problem) because after the reformatting the HDD, the Operating System won't load.
Here's how I was taught to reformat a HDD. maybe someone can see a
glaring mistake:
Create boot disk, insert in Arive and boot up.
Select option 'start computer with CD support'
At the A:\ prompt, type in, fdisk
when asked if you want to enable large disk support, type in, Y and hit Enter
Select to create a Primary DOS partition
The prog will ask you if you want to all the disk space for the Primary DOS partition.Type Y and hit Enter
Press ESC key to exit fdisk and restart the computer using Ctrl+Alt+Del.
After restarting type in, format C: at the A:\ prompt. When you confirm that you want to clean everything of the disk by entering Y the process will remove all data.
Restart the computer when the formatting is complete.
Insert the OS Disk and at the A:\ prompt type in, E: I've tried D, F,G, nor will it accept, setup to start loding OS
This is where I get warnings such as 'Bad command or file name' and I cannot get passed it, so reformatting is incomplete.
I've tried to help the owner sort out the problem and he can't accept that the machine might have problems throughout system. BTW. I am not charging him a brass farthing for doing the work, in fact I'm out of pocket because I paid for the HDD and 64Mgb of memory. I'm not saying that for a pat on the back, it's just that I've pulled my tripe out on this heap of junk and I don't want to pay for the privilege of being called an Ar**hole by him.
All help appreciated
glaring mistake:
