- Joined
- 15 Jun 2023
- Messages
- 22
- Reaction score
- 0
- Country
I've just measured between the wall and the side of the carcass where I'd be putting one of the MDF panels for the "fake" wall. It's 84mm wide at the bottom and 73mm wide at the top...which I think is from the uneven wall as from what I can see with a spirit level, the wardrobe itself looks upright.
The means I'll probably have to cut my panel 71mm which leaves a 13mm at gap towards the bottom. Split in two that's ~7m which was more of a gap than I was expecting. Rather than one long piece of wood, should I split into many smaller pieces?
Any recommendations here?...what would you fill this gap with? Wood filler on the carcass side and caulk on the wall side?
