Friend's bungalow in France, wired by us but signed off properly & connected - no problems.
We have a little gizmo, plugged into a mains socket that receives a signal each day (about 20:00) that says what the electricity tariff will be in the next day. The gizmo shows this as one of a set of coloured leds. It also shows today's tariff in the same way. Presumably, EDF is sending a pulse or signal down the wires that activates the gizmo. I think the tariff/system is called Tempo. Reports indicate huge savings for folks that use this intelligently, since the tariffs for the different bands range from E 0.04 to E40.0 - (Just a guess, but a huge 10 times-ish swing).
Is there an electronic box that could be fitted instead of EDF's little indicator that could be used to switch on heavy power usage kit - immersion heaters or washing machines, for example.
Any ideas, please
Any ideas, please
