I've just replaced my front door. The old door had square edges, so no problem fitting door contacts, but on the new one the internal corner is chamfered. The door edge where it meets the frame is only 5mm which is much smaller than the switches I've found, so whats the best solution? I had thought of putting a PIR in instead, but I see it's not recommended for an entry/exit door.
