- Joined
- 21 Jan 2024
- Messages
- 4
- Reaction score
- 0
- Country
I have 2007 plate Corsa D. When the tempature gets below around 5 degrees or less, I can't get my car into gear. Once I have warmed the car up, approximately 30 mins after starting the ignition it is fine. I have had a mechanic come and look at it and he said my clutch pedal seems low but once the car is warmed up the clutch/gearbox works fine. No sign of the clutch slipping, nor does the car over rev. There is no sign of a leak, soon as the car is warmed up there is no problem at all. Does anyone else have this problem or know potentially what this could be causing the issue.
