Galaxy Dimension - No code setting with A key
5 Apr 2024
Hi all,
I have a query regarding "No Code" setting of a Galaxy Dimension with multiple groups/keypads.
At the moment I have 3 keypads with associated groups specified.
Keypad 1 has groups 1,2,3
Keypad 2 has group 2
Keypad 3 has group 3
Everything works if I set the alarm using a code. However, I'm trying to simplify the setting of the alarm with a single press of 1 button: A key
The problem is, if I press the A key on Keypad 3, it starts the setting procedure but does it for all zones. It also does not honour the parameters I have set. For example, Exit Time has been set to 10 seconds but when I press the A it just sits there waiting and doesn't actually set the alarm.
How do I get the system to only set the group that has been applied to the keypad when doing a Timed Set without a code?
Thanks very much
It's OK guys, I figured it out.
I hadn't removed the B, C and D group parameters for the keypads. Once I removed them it all started to work.
