Did a dry fitting of the door into the frame and it fit perfectly with 20cent coin (2p UK equivalent) gap the whole way around. I installed hinges on the door and was really happy with how flush i got the hinges into the door and frame. In spite of this the door is very tight/doesnt close on the latch side. Before I do anything Id like to run my thinking by an expert.
My thoughts are that the gap between hinge leaves when they are parallel is a little bigger than the gap sought around the door so when the leaves are flush with the door and frame the whole door is pushed slightly towards latch side. (hinge gap bigger that 20cent coin thickness)
My solution i think is to deepen the mortise slightly to pull the door over to the hinge side a fraction (basically the opposite of shimming)? Is this the correct first step for correcting? if so is it better to depend the mortice in the door or in the frame ( or split the difference if its more that a mm?)
