Morning everyone,
Sorry its a long post.
I'm hoping to get some advice about moving a gas meter and supply pipe for an extension I'm planning.
Let me first say i have no intention of carrying out any gas works myself although I can do the donkey work lifting floorboards etc.
We need to move our gas meter and supply pipe from its current position in a small airing cupboard in the middle of the house as it is being knocked through.
If the stopcock and meter could be moved onto the reverse side of the internal wall to where it currently is that would be perfect.
I believe I can get the meter moved within a 1 metre radius but that the rising supply pipe and stop cock must remain where it is, so this option wont work for me.
Hopefully someone can tell me I'm wrong on this front?
So my backup plan is as follows:
In the front garden I have a medium pressure regulator which we moved a few years ago to widen the driveway, so my idea was to get the meter mounted on the front of the house in a direct line to the regulator, have a new pipe layed from the regulator to enter the bottom of a new meter box. I was hoping to then have the new supply pipe run out the bottom of the new box and through the external wall, into the ventilated void below the suspended floor to the boiler and new kitchen which is approx 11 linear metres (4 x 90° bends)
Can anyone advise whether this is an acceptable solution under current regulations.
Is copper the only only way to go or should I be asking about alternatives? From my google searches i believe 28mm pipe would be best used.
I wanted to get the internal pipes in place before asking Cadent to move the meter and supply pipe outside so we can ensure we're not left without heating and hot water and I want to be clear whilst getting quotes.
Thanks for you help.
Tony
Tony
