- Joined
- 23 Apr 2016
- Messages
- 19
- Reaction score
- 0
- Country
Hi all, im new to the forum so hello to begin with!
I have a baxi eco 80 that has stopped supplying hot water to the taps and altogether not firing up when taps running (works fine on the central heating side), the rod on the diverter valve comes out when the tap is turned on and pushes the micro switch, the gas doesnt fire up and the yellow light doesnt come on at the front of the panel (it did flicker on a few times yesterday like there was a poor connection when it tried to fire up) i have found that whilst the tap is running and i tap/knock the control panel(just next to the water pressure dial) the boiler fires up, i have removed each connection that plugs into the pcm board to check for loose connections but to no avail the other fault is radiators getting hot when hot water used to work which i have read is down to the diverter valve but not sure if that would be connected to this fault? hope someone could point me in the right direction,as im not really into cold showers(as i didnt want to jump straight in to a new pcm board)
