how to fit MCB onto Busbar
21 Apr 2016
Ireland
Good Afternoon
I have a 20 Amp Garo MCB
How can I physically affix the MCB on to the Busbar?
Has anyone got a leaflet showing info on the MCB
Many thanks
From a data sheet linked from here https://www.rapidonline.com/garo-mcb-grc120-20amps-1pole-mcb-c-curve-6ka-1-module-13-9454
Miniature circuit-breaker 6kA. This item is capable of protecting the system against short-circuit current up to 6kA. Equipped with a mounting bracket that allows you to remove or install a miniature circuit-breaker even when the phase busbar is installed and is compatible with all GARO busbars for miniature circuit-breakers.
It requires the compatible bus bar to be correctly and safely installed.
