It isn't easy.
So when you learn a device to the panel, the wireless network is assigned.
This is supposed to represent the best channel currently available at the time other devices learn on to that same network.
Been a while since I last did anything with this so hooked up an old elite panel with built in wireless expander.
And engineers keypad on the expander, more modern Elite panels don't have the engineers keypad connection available.
so I learn on a device, I can see using the engineers keypad on the expander its Network 28.
I do a series of deletes and relearns, checking the wireless network every time.
Had 2 on network 29 and one on network 31. So can see the network has changed.
So looked at this panel via wintex and ricochet monitor (available Elite V2 with V2 plus wireless expander), and in ricochet monitor you can see the wireless network is displayed, this means you can check it versus what you had originally even if the engineers keypad on the wireless expander part of the board is unavailable.
What I cant tell you is how many networks are available or how they are distanced wrt to frequency changes between each network.
So the question is what networks have you confirmed are having issues.
The other thing it is potentially possible, to hit a quiet spot and be on the same network that is having issues, or the jamming is spread over a wide range.
If this seems complicated don't have much time at the minute and its a bit rushed so apologies.
