Hi
I am wondering if anyone came across the following issue with ICOS boiler. Suddenly, it has started making loud noises - first every half an hour, then every 10 minutes and then it stopped working altogether with an FL or LF failure code on the display. If I reset it, it makes the noise again, but fails to start.
I called the plumber. When he came and switched the boiler on after 12-18 hour break, the boiler made these sounds once but then kicked into life. Plumber spent three hours and charged 180 pounds (though I am not sure he actually understood what was the problem - a fan was mentioned, but he did not want to replace it just in case), but three days down the line we are back where started.
Could you tell me what may be the problem with the boiler from the sounds that it makes?
I don't really have money to "burn" and I am not confident that the problem will be addressed without outside expertise.
Please see below:
Please see below:
