insinkerator 3 in 1 F-H3N1 - hot water coming through vent and Leaking
26 Jan 2009
Bristol
Hi. I have an insinkerator 3 in 1 F-H3N1 which when you use the hot (boiling) water tap, cold water has started coming out of the vent hole on the tap.
The instructions suggests this could be a result of a blocked outlet hose but I’ve checked and can’t see that it’s blocked.
After running it a bit, the vent hose on the right hand side of the boiler unit now pops off every time you use the hot water tap.
Any ideas how to fix it?
I haven’t changed the first for a while- could it be that?
Pete
Hi pete
Did you ever figure out the issue … we have the same tap and same problem !!
