Laminate underlay confusion.
30 Jan 2021
I've perused the threads on this and still unsure. Last week I had 7mm laminate click fit installed in a lounge diner. The fitter rolled a foil backed underlay over the bare floor boards. I'm thinking of having a go at the hall myself. Wooden 80yr old floor boards. I've bought some 12mm Laminate on offer from Wickes. Do I need to level the floor as the fitter didn't bother in the lounge? He also looked at the kitchen and thought he could lay directly over the old stick on vinyl tiles, go to the wall and put the washing machine, fridge and freezer on top. Is this ok? Any advice on correct underlay appreciated. Its a jungle out there with price and choice. Thanks.
Thanks for info. One other thing if I may ? The packaging on the laminate says I should use 5mm foam underlay on a wooden floor and a 3mm damp proof membrane on concrete. Surely this means as the kitchen is a mix of both wooden and concrete I'll end up with two levels at the joint?
If it is bare concrete with nowt on top then yes, dpm first.
Never fill up to walls with laminate in a kitchen and then plonk appliances, cupboards on it. If it is a floating floor that is..
The kitchen floor is covered with stick down vinyl planks. I'm thinking of going over the lot using 5mm foam. Cheers
