Good Evening,
I have a question about l
aminate flooring. I have to lay it before the plasterer will put the skirting on (apparently..) If you look at the picture below, the hallway upstairs is a funny shape, a plus sign, and the top is an alcove to the window, black is the outline with walls, orange is the doors. Joists go left to right, floorboards up and down. So it would make sense to run the boards left to right, in theory I was thinking I should start in the top left corner here it says joists and make my way down to the stairs, and then "backfill" into the alcove at the top, because then I'll know it's straight. If I start in the alcove, when it gets to the main bit it could be well wonky. But then I'm thinking what's the best way to back fill, because it'll be a nightmare trying to click them in that way. The easiest way would be to go with the floorboards I guess, and then the second bit is how should I stagger the boards in the narrow parts, it's about 85/95cm, how can you stagger it randomly? I guess if you did an 8" to begin with and then ... 9 inches the opposite side you would still be able to keep the joins random without getting too close or stepping.
I'm beginning to understand why people just lay carpet now... but I hate carpet.
Any help would be much appreciated.
Edit: Maybe I should start from the bottom right and work my way backwards to the window, the "alcove" to the stairs is only 30/40cm, the alcove is almost square so 85/90 cm.
