I'm looking to get the loft boarded in a new build house.
I'll be looking to use the LoftZone system, but currently in a dilemma which board to use.
The LoftZone shop are currently selling Supreme Loft Boards which are P5 (which is moisture resistant and load bearing), however, the installer say they only use P4 (not moisture resistant).
Installer are saying that P5 is more for high moisture areas such as kitchens and bathrooms and not for lofts. They state on their website, that water vapour rises in the house and ends up in the loft, if it meets a moisture resistant board, the water droplets will condense and fall back onto joists, causing them to rot over time. This is why they say a P4 board is better.
Is this correct? I would've thought given there is going to be an air gap between the insulation and the board - natural ventilation in the air gap will wick any moisture that rises away.
Would a P4 board be better than a P5. I thought the P5 would be better in case of any spillages or water ingress from the roof, a P4 would just disintegrate causing any stored items to potentially fall through the ceiling. Whereas a P5 board will be stronger and be able to withstand such issues better.
Another thought is perhaps a P4 board will highlight any condensation issues better as it's more susceptible to moisture.
Any help you can provide on which would be the better solution would be greatly appreciated.
