Matki MODEL LCQ Illusion Quintesse Door
26 Nov 2015
Good afternoon, the door on my Matki LCQ Illusion Quintesse shower enclosure keeps springing open. Can anyone provide information on how to adjust this type of door so that it stays shut when taking a sower? I have been unable to find detailed information on how to achieve this.
Ideas gratefully received.
I've got 3 of these in my house.
The hinges provide the adjustment, but if the glass side panels haven't been installed vertically it will never shut properly.
Thank you, that's very helpful. The door has been working just fine for about 8 years so I'll assume it was originally fitted correctly. Can you advise how to access the hinge adjustment as it looks to be covered by a chrome plate.
Pry off with a thin-bladed s'driver.
Email Makti nicely and ask for a set of installation instructions for your model; door/hinge adjustments will be in there.
Many thanks to all who responded.
I have since been able to access the hinge screws and make adjustments to these hinges. While carrying out adjustments it became clear that the main issue here is actually stiffness of the hinge itself to any movement! I have tried lubricating the hinge a couple of times with WD40 specialist easing oil but with no real success.
Can anyone suggest a different approach?
Thanks in advance for any advice you can provide
Three showers, Simon?
Seriously impressive. Especially at my end of the social spectrum with just one humble bath/shower mixer.
Doffs cap respectfully......
Actually, not very impressed with Matki..... the two main ones are suffering from blisters on the trays, they've lasted around 10-11 years and are now suffering from a sort of osmosis.
Changing them will be a mission.
I hope someone here can help - I would like to urgently source a replacement glass door for my Matki Quintesse Illusion shower unit - right hand hinge, left hand handle.
The width is 530mm - the previous one shattered in an accident. I believe all doors in the range are the same, I have the hinges and hardware, just need the door. Matki can’t help (although there Tech team are excellent) - trawling dealers but if anyone has a door going - let me know.
