My mum has a Miele Novotronic Premiere Plus, purchased around 1997. Recently, it started to leak during cycles, but was still able to wash clothes. We pulled it out to have a look at the pump (where problems have arisen previously) and now it is leaking far worse.
Currently, as soon as we switch the machine on, water comes in the back, through the detergent drawer, through the drum inflow, drum outflow, and out through the pump filter flap (front bottom of machine). It is not flowing out through the main drainage pipe. It is not spending any time in the drum.
Here are our observations:
- the pump rotates when the spin cycle is on
- the pump does not rotate when the machine is filling
- the drain pipe at the back is clear, and positioned higher than the pump
- the main drain pipe from the back of the machine looks intact
- the outflow pipe from the detergent drawer to the drum inflow pipe is not blocked
It seems like maybe we dislodged something as the problem got a lot worse after we moved it around and took the pump and pump filter out to have a look at them.
We wondered if maybe we have done something to a pressure sensor?
Any advice on what we can do to diagnose/fix this greatly appreciated.
Thanks,
Katie
Thanks,
Katie
