- Joined
- 30 Apr 2022
- Messages
- 1
- Reaction score
- 0
- Country
My living room is on ground floor. It has a suspended wooden floor over a large vented cavity (several feet deep). It gets pretty cold in winter. I want to get carpet in this room; both for comfort and to increase the warmth/insulation in the colder months. I’m aware that doing under-floor insulation would be the best way to insulate this room, but it’s a large room and this would be expensive and disruptive so I’m unlikely to go down this path at present given my budget.
I want to get the most insulation I can from above-(floor)board insulation/underlay/carpet.
I came across this ‘Eco-Tech floor foam insulation’ stuff online which seemed like a silver bullet for my situation; as a solution to increase insulation above floorboards (but below carpet underlay):
https://www.ecohome-insulation.com/product/ecotec-floor-foam/
But delving a little deeper I’ve begun to think it may just be snakeoil. I can’t find much in the way of genuine trade advice on its effectiveness and or suitability for this situation. I’m also concerned it would effectively form a waterproof membrane above the floorboards which may ultimately lead to issues of mould/damp under the underlay. Any experience/trade-level advice most welcome!
Whether or not I the above, I’ll be looking at filling gaps in floorboard best I can the getting the max tog carpet/underlay combo. The best rated underlay I seemed to find was Wilsons Plushwalk 12mm:
https://www.carpet-underlay-shop.co...ushwalk-12mm-carpet-underlay-from-3-05-per-m2
…but this seems to have a damp proof membrane (DPM) built in – and again I’m concerned that this could cause issues like the above given the nature of the floor underneath (suspended wooden floorboards over vented cavity). Is this a valid concern? Would I be better with a non-DPM underlay?
Any advice on any of the above – or alternative solutions to getting the best insulation I can from above-board (literally!) work in this room would be most welcome!
Many thanks
Many thanks
