Champion self propelled mower.
I removed both rear wheels, circlip, drive gears & pin through the shaft.
Cleaned it all up & put back together like ive done many times.
Now when i start it up & operate the bar to engage the gearbox & drive the wheels the wheels dont turn.
Ive done the following to check it out but still the same.
Undo the center wheel but just in case it was to tight.
Removed it again just incase the pin in each wheel was stuck in the shaft.
Neither made any difference.
With grass box removed & mower off the floor i operate the bar i see the drive shaft from gearbox spinning quickly no problem BUT wheels not turning.
With mower off & lifted off the ground i spin the wheel by hand & see the shaft turn no problem.
With the wheels back on & mower lifted off the ground i no look at the shaft that passes through the wheel, i operate the bar & i see the shaft spinning fine BUT no wheels are tuntning.
Im lost as to why
Im lost as to why
