my new home needs some renovation, at least painting, but I was looking at oak panels, although they are more expensive in UK, they should be kind of immortal, I would hate painting the house again in 5y or so.
I could make it with the price, the problem is that I thought to what would happen if any water leak or infiltration from the outside came up, how would I notice? By the time I noticed, everything rotted inside…
This issue is quite a deadly threat for a stick frame home (or whatever wood frame) and I’m thinking that it’s just an unnecessary risk.
In case you wonder, the expense is 2k max against 7k with panels, bathrooms probably not included, I’d like to make it full tiles, excluding the ceiling.
House size 83 m2.
The plaster has 10y already, I hope I don’t need to remove that first , if I paint it now, how long will it last? Supposedly using the best paint, many layers and a finishing coat as water repellent.
All will be done by a professional, I won’t have the time to do it all by myself while living inside, plus, I want a proper job done.
What would you suggest?
House size 83 m2.
