Hi, I'm in the process of renewing some plumbing work from copper and compression fittings to pushfit plastic in my bathroom. It's a mixed system gravity fed hot and mains pressure cold, The hot water tank is only marginally higher than the bath taps at around 1.5 metres. Currently the Hot water pipe enters the bathroom at 22mm but is then reduced to 15mm for about 1 metre up to the hot bath mixer tap. In short my question is why would a plumber do this and what effect would changing it to 22mm all the way to the mixer tap be? As this is a practical issue practical answers rather than theoretical fluid mechanics please. Thanks guys
