Ok so i've made a bit of botch up.
I lightly sanded down some exterior gloss window frames and primed using dulux primer under coat and then painted the frames using dulux satin wood which is only suitable for interior instead of the gloss which is suitable for exterior.
Can I paint over satinwood with gloss or will i have to prime/undercoat all over again or will a light sanding over the satinwood sufice befote i repaint using gloss?
What grit sandpaper do i use, i have some 180 which is the fine grit?
Any help appreciated.
