Pryronix enforcer - Low Battery - 'Input 02'
11 Apr 2023
Have active fault, 'Input 02' - low battery. I haven't seen this before as normally says which PIR it is by name or if siren/control panel etc.
Is there any way of specifying what it is. Not sure how to remove fault otherwise?
One of your inputs, in this case 02 hasn’t been named on the panel so it’s just showing the default.
Do a walk test and see when it triggers.
All sorted. Thanks. Sorry for delayed response. Your walk through test did it by elimination.
