Pyronix Euro 46 strange tag issue
3 Jan 2014
Middlesbrough
Hi all
helped a family member out today by adding a new fob to their panel to replace a lost one
easy enough to do, the actual programming took less than a minute
when time came to set the system, we tried the new tag, and whilst it was recognised fine upon leaving the house the exit tone did not stop
upon going back in, i couldn't use any of the other tags or the code to cancel the set only the new tag which i found weird
it's almost as if it got stuck in exit mode from the new tag
set fine with one of the other tags straight away afterwards
any suggestions? first time this panel has even given a slight bit of bother
Have another try. Could have been a glitch when it triggered the wireless arming process.
there is only 1 area set up which is area A
they're getting on in age, live in a bungalow and have many toilet trips/letting dog out at night so no need for anything other than a full set (used daily)
24 zones in total, all in use, glass break detectors in most rooms on 24hr alarm, PIRs and contacts become active on full set
in theory this should have worked perfectly, albeit i haven't tried since as i just used one of the other fobs as we had to go out
if the wrong code or tag(faulty tag can give an incorrect rfid) used, after a few attempts, it'll lock the keypad out for about 10 minutes(could be longer)- code guessing tamper.
