I'm looking into using Quinetic receivers for lighting and see a lot of entries on the forum. But I can't find an answer so hoping a user can help.
Does the receiver require a minimum load for the lighting. I've had problems with electronic switches before when using standard mains LED lamps (mains not low voltage) commonly available.
I saw an entry on the Screwfix forum where someone had problems which were cured when he/she used a filament lightbulb instead of LED. However, I'm not sure if it were wiring or the lamp.
Also, if there is a prolonged power-cut will the transmitter/receiver have to be re-paired?
If so, that's a pain.
Thanks.
Thanks.
