Radiator on studs on top of bricks
19 Jun 2019
I need to hang a radiator (160cm wide, 50cm high, total weight around 35kg) via two brackets to a plasterboard wall.
The wall is external, so that it has studs (about 12mm deep and 50mm wide) behind the plasterboard and then bricks behind the studs.
I am lucky enough to have studs in correspondence of my brackets.
However, I was wondering whether the 12mm depth of the studs would be enough for the screws to bite, or if I should reach to the bricks behind the studs and fix the brackets to them.
If I can use the studs, how do I make sure that the screws go through the whole 12mm, given that this will be prevented by them hitting the bricks?
Thanks.
