Remove battery from sounder
25 Sep 2022
We moved into a flat with a texacom premier 24 alarm about a year ago. we were not given any info about the Alarm , no codes and there are various fault messages flashing . It’s a very secure flat anyway so was never bothered .
The sounder outside the front door has now started chirping as I assume the battery is close to dying.
Can I just remove this off the wall and take the battery out or will this cause the alarm or go off ?
If the alarm does go off I have no way of deactivating it
iosolate mains supply to control panel , then disconnect battery from control panel ….then do same at the bellbox ..
