I have a Scantronic 9000 system which is about 27 years old, only needed occasional backup battery changed and the 16ohm speaker in the bell box changed over 27 years.
Just had to reconnect the speaker as one of the wires had corroded through, sounder now works. The strobe however is not working, I suspect the bulb but it could be a panel fault.
Is it possible to replace the whole bell box with a AG3 Intellisense Bell box?
The AG3 has a siren in it as well as a strobe which I am led to believe uses high voltage to run the siren and strobe as opposed to the existing box that uses the 16 ohm speaker.
