Replacement wardrobe backboards
Hello, I don't know exactly what you need but Just asking - do you realize that you need to pull the wardrobes out to access the back boards?
Unless they are completely cream crackered you can often nail/staple them back in place.
I used to run wood glue down the back before fitting them and nailing them in place.
If you do pull the wardrobes out you can then measure them, then pop off to your local woodyard and they may have some 6mm painted MDF sheet that they can cut to size for you.
Or if it's not painted, you can do that yourself with a roller before fitting it.
If you cannot pull them out (i.e. they are fitted) then you'd have to run some beading down the back edge ready to accept new boards cut to size that can be nailed onto the beading.
if its at all discoloured or even mouldy then remedial action will be needed first
