Our Sebo x4 has stopped working and now appears to have no power at all. I have started trying to diagnose the issue with a multi-meter and get the following results when testing the power cable from plug to switch (or prior to switch):
20 ohms (approx) for one connection.
OL for all other connections.
This doesn’t seem right to me. I expected to get a low ohms reading for testing each of the live and neutral pins and OL for each pin when when testing the other wire at the switch end. Is that correct and, if so, what do the readings I get suggest?
